Old 07-23-2004, 11:02 AM
monomial monomial is offline
Question will 96 parts fit a 92?
I can pick up a 96 VR4 cheap. Will the tranny, axles, radiator, turbos etc. fit my 92? I would like to get the 6 speed tranny in.
Old 07-23-2004, 11:41 AM
Igovert500's Avatar
blue + red light magnet
Re: will 96 parts fit a 92?
Turbos will, I'd assume the axles, tranny might take some fabrication if you're switching from a 5spd to a 6spd...I'm not entirely sure though...
http://www.stealth316.com/2-5spdto6spd.htm
that details all that is involved in the conversion.
The radiator I don't even have a clue on, the headlight buckets are different between the two cars, so i don't know if that would affect the radiator in anyway.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-26-2004, 11:56 AM
lemon1438 lemon1438 is offline
Anything and everything can fit on the 92 from the 96 as long as you use the complete combination. As in you need to swap the tranny, transfer case, axles to convert into a 6speed. Radiator you will need to swap and weld the radiator support. No need to swap turbos unless your 92 turbos are blown. For the front end you will need to swap the hood, bumper, lights/turns, headlight buckets unless you want to mod/cut away your current buckets.
-Ryan
