Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-23-2004, 10:47 AM
Bulldog Brewer Bulldog Brewer is offline
Send a message via Yahoo to Bulldog Brewer
Coil Spring Replacement
Good day! Going to install a set of front coil springs on my 89 Ford Ranger 4 wd Supercab this weekend. Any advice or tips before I begin?
Thanks
Derrick
New Brunswick, Canada.
Old 07-23-2004, 12:22 PM
EVH5150 EVH5150 is offline
Re: Coil Spring Replacement
use alot of PB Blaster to help loosen up that bottom nut that holds the coil in place. Also disconnecting the front sway bar from the frame will allow a little extra travel of the TTB to help remove the spring, other than that, good luck.
Old 07-27-2004, 09:01 PM
Thanks. Whats PB Blaster?
Old 07-27-2004, 09:23 PM
I Heard it on another website. Also known as Rust Eater or that stuff you spray to free up rusted bolts. Sorry about that...Are those lifted springs you're installing, or just stock replacements?
Old 11-04-2004, 08:00 PM
littledevilbkr23 littledevilbkr23 is offline
Banned
pb blaster is a higher grade wd40, it works about three times as good
Old 11-29-2005, 01:24 AM
dumped 00 dumped 00 is offline
Talking Re: Coil Spring Replacement
Thanks
Derrick
just make sure you get the right kind of coil compresors... they should be enternal not external
