Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-23-2004, 09:32 AM
Yacob Yacob is offline
Question 94 Camry wagon brake light replacment
I need to replace a rear brake light in the back door but can not figure out how to get into the unit. It is probably very simple but I just don't want to ruin the rear panel getting in the wrong way.
Old 07-23-2004, 05:54 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 94 Camry wagon brake light replacment
If you're referring to the high-mounted brake light, the cover comes off by inserting a pointed object into the round clips. They are inserted by pushing the pin back through the clip, inserting the clip in the holes, and then pushing the pin back through.
Old 07-26-2004, 10:27 AM
Re: Re: 94 Camry wagon brake light replacment
I am actually referring to the lower brake lights. There don't have an obvious access that I can see.
Old 07-30-2004, 04:31 AM
Bossman Bossman is offline
Your owners manual should have illustrated instructions on how to replace any light bulb in your Camry. Best of luck!
Old 08-03-2004, 09:04 PM
Unhappy Re: 94 Camry wagon brake light replacment
That would work great if I had an owners manual, but I don't. Any suggestions?
Old 08-03-2004, 10:50 PM
Brian R.'s Avatar
Resident Chemist
Are the lights you are talking about on the door or the body?
Old 08-04-2004, 10:16 AM
The light I need to replace is on the door.
Old 08-04-2004, 12:29 PM
Brian R.'s Avatar
Resident Chemist
You have to open the door and remove the inner panel that covers the area where the light is at. Probably by prying it off with a taped screwdriver. Then there are 4 nuts that hold on the exterior lens assembly.
