Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 07-23-2004, 12:30 AM
StealthZ32 StealthZ32 is offline
Send a message via AIM to StealthZ32
Oil Pan gasket
Is it me or are the front and rear gaskets a little small? Seems really small to me. Anyway, I plan on doing this with my friend and he said we can do it in the driveway. Anyone had experience with this? Anyone have any tips oha quick easy way to do so?
R.I.P 2008
status- stolen by the motherf#@$%! that i knew! haven't seen him since Still have the engine like that does any good
Old 07-24-2004, 02:46 AM
RX_speed's Avatar
RX_speed RX_speed is offline
Send a message via AIM to RX_speed
Re: Oil Pan gasket
huh? im confused, what are you going to do?
1986 Mazda RX-7
1991 Nissan 300ZX
Old 07-24-2004, 04:30 PM
putting a new oil pan gasket in. When i bought them they looked really small but on the box it says they are the front and rear gaskets. Any easy ways to achieve this in my driveway?, my friend says he can do it.
R.I.P 2008
Old 07-25-2004, 07:15 PM
RX_speed's Avatar
Re: Oil Pan gasket
i just did it last night. the gaskets fit fine and i used silicone sealent on the rest of the oil pan. make sure you have the right gasket
you can do it in your driveway. just jack up the car, drain the oil, remove all of the 10mm bolts from the oil pan (i had to remove a bracked to get to a few of them), then scrape off all the old gasket and put in the new ones and some sealant. be sure to give the sealant time to dry
1986 Mazda RX-7
1991 Nissan 300ZX
Old 07-25-2004, 07:28 PM
nice how much time to dry?
R.I.P 2008
Old 07-25-2004, 07:49 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: Oil Pan gasket
most likely depends what sealent you used... if it's silicon based i'd give it 24 hours... that's to be super safe tho
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 07-29-2004, 11:06 AM
great thanks a lot
R.I.P 2008
