| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
I have a 91 explorer with a 93 explorer motor,v6.....It's a 5 speed manual shift,when i shift my exp to different gears alot of times it will start bucking and it also does it when my foot is totally away from the gas pedal....it also bogs out like the fuel isn't getting to the engine injectors or like i'm out of gas....could anyone help me with my problems
#2 | |
![]() Join Date: Dec 2003
Re: 91 exp.starves for fuel when shifting gears
Sounds like the clutch is slipping.
#3 | |
has your engine light come on? this could be spark plugs or ignition wires too.
#4 | |
On rare occasions, it is the fuel pressure regulator. Some of these have a spring that isn't centered. This causes the valve seat to wear only on one side. High vacuum conditions (foot off the gas)cause the valve to open more and it sticks open on the side of the bevel, dropping fuel pressure. When pressure tests are done, everything usually seems normal. If you don't have a pressure gauge to monitor the fuel rail (34# idle, up to 39# open throttle, engine dies at about 20#) the fuel pump fuse can be pulled (1/4" spade terminals fit in the fuse socket) and wires run into the cab to a 10A meter. Normal is about 4-5A and current will vary about 1/4A in driving. Engine will die when it drops below 2A. This will at least identify if it is a fuel problem.
