Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-22-2004, 11:46 PM
S15Drifter12 S15Drifter12 is offline
Civic Si not running right
i have a civic si with a jackson racing supercharger, NOS, and lots of other things, and ever since i had the car professionally tuned and had a hondata s200 installed, the car runs like crap. it doesnt pull like it used too. also after the spark plugs have been in the car for a while, it starts sputtering at about 5500-8000 where i shift. the sputtering wont let me accelerate anymore in the range. wen i change them, i can get about nine runs on the 1/8 mile before it starts sputtering again. the car ran a 9.3 on a 1/8 mile and ever since i have had it tuned, the best i have gotten out of it is a 9.8. i have had this probly for close to a year and any help will be greatly appreciated.
Old 07-23-2004, 01:27 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: Civic Si not running right
Sound's like tuning gone bad. Get someone else to take a look at it.
9.3's with a supercharger and nitrous? that's kind of weak man...
What year si?
2002 Acura TL Type S
1991 Honda Crx Si
Old 07-23-2004, 10:24 AM
its a 2000 si. its only running 8 pounds of boost with a 60 shot of nitrous. does the tuning also affect the problem with the spark plugs?
Old 07-23-2004, 01:58 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i would take the car back to that tuner and tell him i paid you good money and my car runs like shit.
did you get the right temp spark plugs for you setup?
Team Lonely Drivers
Old 07-23-2004, 02:18 PM
well after i got the car back from the tuners, i emailed and called them a million times and they never returned any email or call. so i found the next closest place to me but they dont do dyno testing. they are the ones who told me wut spark plugs to get and wut to gap it to. im just really pissed and want to fix this problem. is it tuning or something else?
Old 07-23-2004, 05:10 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
do you have an aftermarket Fuel Pump?
What fuel mods do ya got??
Ya, It's Turboed.
Old 07-23-2004, 10:48 PM
440 Rc engineering injectors, str fuel rail, i had a aftermarket fuel pump but the tuners thought it was "better" if i took it out. i still have the aftermarket one.
Old 07-24-2004, 12:10 AM
you deff need an aftermarket fuel pump in there it's probably not supplying enough fuel to the injectors for the nitrous and supercharger to work correctly.
1991 Honda Crx Si
Old 07-24-2004, 03:29 PM
i will change that out asap but wut about the problem with the spark plugs?
Old 07-24-2004, 08:50 PM
i was looking at the car today and i realized i made a big mistake on one of my post. i DO have a aftermarket fuel pump (Jackson Racing) but i dont have a aftermarket fuel pressure regulator. i do have the Jackson Racing fuel pressure regulator in a box thou. sry bout that. thanks for everyones replies so far
Old 07-25-2004, 06:16 PM
jeffseby's Avatar
yep better finish the fuel system and make it correct before anyone is blamed. Ya with that setup, you better have a fuel pump!
Ya, It's Turboed.
Old 07-25-2004, 09:45 PM
i dont mean to be annoying but wut is causing the problem with the spark plugs becuz its getting annoying that everytime i go to the drag that i have to buy new spark plugs
Old 07-26-2004, 04:13 AM
how do the plugs look when you take them out ?
Team Lonely Drivers
Old 07-26-2004, 02:10 PM
they look normal i compare them to the hanes manuel i have and nothing is wrong with them. im using NGK R spark plugs if that helps any.
Old 07-26-2004, 11:46 PM
b16a3sol b16a3sol is offline
have you tried just reseating the same plugs? just take the same ones out and put them back. spark plugs are pretty simple, so if they look fine, i cant see why they would be failing.
does this happen on the street as well, or only when you are at the track? are you doing all 9 runs in the same night, or are they spread out?
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
