Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 07-22-2004, 11:35 PM
mancur mancur is offline
93 Olds 88 overdrive rumble / vibration solved
When: 50-60mph, just as the car drops into overdrive and the RPMs drop to 1500-2000.
Symptoms: Hesitation, rumbling, front end vibration, car lugs as you step on the accelerator.
Cause: In my case...a bad spark plug wire causing only 5 cylinders to fire.
Fix: Replaced all the spark plug wires. $20.
I had suspected everything from bad CV joints, to loose engine mounts, to a bad transmission.
Old 07-23-2004, 12:18 AM
Ofnarcr Ofnarcr is offline
Mine does the same thing. Gets to about 60 tho and starts vibrating.
I need to replace the spark plugs and wires too anyways.
