Old 07-22-2004, 10:21 PM
zippyjeff zippyjeff is offline
AC Vent trouble
The vents on my 94 Mustang GT no longer work. The a/c and heater both work really well, but blow out the defrost vents. What's up with that??? They worked in the morning going to work, but not on the way home in the afternoon. Any suggestions???
Old 07-23-2004, 12:51 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
I had a similar problem when I forgot to reconnect an AC vacuum line on my car. It worked, but it only went through the defroster. Perhaps you have a bad vacuum line?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-23-2004, 02:58 PM
lenny0861 lenny0861 is offline
Re: AC Vent trouble
in the engine compartment towards the back you will see a vacuum line disconected that will be your problem it happened to me twice
Old 07-27-2004, 10:56 AM
Re: AC Vent trouble
Thanks...that was the problem, except mine actually broke, had to get a new line.
