Old 07-22-2004, 10:16 PM
zippyjeff zippyjeff is offline
Angry 94 GT Pinging & Knocking Noise ~ HELP ~
I have a 1994 Mustang GT 5.0 with a manual transmission. There is a pinging and knocking noise emitting from the engine when you accelerate and everything I have done has not helped! I have had the timing reset (by Ford dealer), new spark plugs, cap, rotor, wires and had the throttle body and injectors cleaned. It does not matter what type or brand of gasoline you run, I've tried just about everyone of them and grades. First thing in the morning (about 5:00 am) it runs okay, but when the engine (or air outside) heats up the worse the pinging and knocking sounds get. It sounds like a bunch of rocks or marbles tumbling around in there.
Any information will be helpful, as I am at the point of putting a new crate engine because the sound is soooo annoying and embarrising while driving.
Old 07-23-2004, 12:54 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Pull codes!
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
