Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-22-2004, 09:58 PM
Accordh22 Accordh22 is offline
h22 auto vs manual swap
Hi, I have a 2000 accord 4 cyl (auto...haha...I know). Anyway, My plan is to either go turbo on a manual swap or supercharge the auto H22. Should I get the auto H22 and then supercharge it? I don't know know which route to go, which is cheaper in the long run? Also, what if I do a auto to manual swap on my f23 and then turbo that vs. swapping out my whole engine. Thanks for any input.
Old 07-30-2004, 03:25 PM
Darhemady1 Darhemady1 is offline
Its Easy
If I remember correctly, the f23 is non-vtec right. The h22 is v-tec and has higher compression than the f23 and you want as much low compression you can get if you want to run alot of boost on your engine. Do't get me wrong it is possible to turbo an h22 but it would be cheaper to turbo the f23 because of its lower compression and I swapped out my trasnny to a stick as well that is probably the best thing to do and alot cheaper!
