Old 07-22-2004, 09:02 PM
cord222 cord222 is offline
Over heating while towing
I just bought 24 ft. Travel trailer when I was towing it home with my
2002 TB I seem to have some problem with the engine heating up quiet
a bit more than normal (it went as high as 235-240 degrees) I pulled
over at this point so I dont know if it would have went any higher. My
TB is a EXT with Long 6 cyl. and 3:43 rear end, trailer weights just under
4,000 lbs. unloaded which is about 1,000 Lbs under my tow cap.Does
anyone have some input on this because its nearly made sick
I didnt expect to have this problem........ THANKS
Old 07-23-2004, 12:15 PM
Bullethole Bullethole is offline
Is it overheating or just getting hotter? Most new cooling systems can tolerate heat past the boiling point if the coolant is the correct mixture of antifreeze and water. Part of the emissions control is to have engines run hotter so as to be more efficient. Obviously pulling a trailer such as yours will make the entire system work harder, especially the transmission which is cooled by the radiator also. I would suggest aan additional trans cooler to help take some of the load off the cooling system. Your trans will thank you for it.
Old 08-03-2004, 10:56 AM
Deadcarny Deadcarny is offline
Re: Over heating while towing
I just towed my Z28 to NYC with my TB with no probs. Gauge barely went past halfway, and outside temp was in the upper 80's to mid 90's throughout the trip. The Z28 weighs about 3500 pounds in the trim it was on the trailer in, and the trailer is a very large Car trailer with a diamond plate steel bed. It probably weighs close to 1500 pounds by itself, so I would say my load was close to 5000 pounds. Gas mileage was near 13mpg average while pulling the trailer and car.
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100
1967 Chevrolet Impala (Sold)
1972 Chevrolet Chevelle (Sold)
1972 BMW R60/5 (Sold)
1980 Harley Davidson FLH
1987 Harley Davidson XLH
1992 Astro EXT AWD
1992 Chevrolet Cavalier
2000 Monte Carlo SS Pace Car 1087/3222 (Sold)
2001 Pontiac Sunfire
2002 Trailblazer LTZ (Sold)
South Carolina F and Y Bodies
www.SCFYB.com
