Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-22-2004, 08:44 PM
neogenesis neogenesis is offline
Hesitation start.
I went to my car today to start it and it started fine when I turned to key, but this time the car didn't even rev up high. It was hesitation and I had the feeling the car was going to stall becuase the car was also shaking a little. Then I saw smoke infront of me but it was coming from my exhaust so I went out and saw a thickish fog of white smoke coming out wiht a strong gas smell. I then went back to the car and it was still in the very low rpm, so I try to give it gas to rev around the 2k area but nothing happened when I gave it gas, so I floored it and still nothing. Then soon the car started to react to the gas and rev'd as I wished. Everything then seem to be okay. Oil temp is fine, oil pressure, gas pressure, and gas guage all fine. I wonder if this is a boost leak...but I doubt it since I didn't hear anything when driving and I didn't see blue smoke so that's a good thing. Anyone know what happened to my car? I'm going to go out tomorrow again and see if it does the same thing. Any help would be highly appreciated!
Old 07-22-2004, 09:12 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: Hesitation start.
you might have a leak somewhere. i would check all your fuel lines. when you say you saw smoke in front of you and the noticed it was coming from your exhaust, do you mean it was coming somewhere from the exhaust system in front of you?
ZedEx Crew Member #2
Old 07-22-2004, 09:21 PM
No, I meant the smoke just flowed to the front from the exhaust tip pipe.
Old 07-22-2004, 10:25 PM
ohhhhh, okay. then i don't think it is some kind of leak. since your smoke had the smell of fuel, there is a few reasons, 1)malfunctioning fuel injectors 2)stuck throttle bodies (not enough air so there is a strong fuel/air mixture) 3)bad ignition (not burning all the fuel). these are just ideas. anybody else?
Old 07-22-2004, 10:40 PM
I was thinking those too, just needed more ideas. I think the F/A mixture was off for the moment. Could it also be my spark plugs?
Old 07-22-2004, 10:49 PM
yeah, spark plugs are included in my ignition reason. what i would do, is if she is doing it again, listen for the little clicks and make sure they are constant. each coil makes a little clicking noise everytime it fires. but sometimes it is hard to tell.
Old 07-23-2004, 07:43 AM
Alright thanks for the tip. I'll be sure to check for that later today. Does local stores sell the NGK spark plugs? Like Murry or Autozone?
Old 07-24-2004, 01:48 PM
akirapowerz akirapowerz is offline
Talking Re: Re: Hesitation start.
i agree with you on this one thier is only one other thing i would ad is the wiring harness to the injectors becouse is thier loose well you kown and u he said ngk right thinking only use nissan spark pluges becouse nissan is natoriouse for only using thiers dont go out and buy bosh platnum goo posting great advise
Old 07-24-2004, 08:27 PM
Do you know if local stores sell NGK Spark Plugs?
Old 07-28-2004, 08:34 AM
Damn local store is asking $26.99 for NGK Turbo Plugs...Might as well buy them at courtesyparts...
Old 12-10-2005, 10:59 PM
nyczbubba nyczbubba is offline
any updates to what happened? I have the same problem I've tried contacting u through PM's but no answer let me know please
Old 12-11-2005, 12:00 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: Re: Re: Hesitation start.
neo doesnt come here very often anymore and this thread is 2 years old.
if you have any questions you are more than welcome to start a new thread.
ZedEx Crew Member #4
Closed Thread
