Old 07-22-2004, 07:20 PM
neevie2003 neevie2003 is offline
Send a message via AIM to neevie2003
Angry 1997 blazer
I need help!!!!!!!!!!!! I traded my 92 firebird to a 97 blazer and have had nothing but problems!!!!!! I was on a trip and on the way home my blazer stalled on the highway and i got it running and went and put some gas in it because if it gets under a quarter of a tank it doesnt want to run. It started right up and it didnt try to quit any more after i put some gas in it then i parked somewhere and turned it off and it wont start back. The fuel pump is working but it is not kicking in every time you can hear it when it kicks in but anyways it is getting fuel up to the throttle body could it be the fuel pump or is it something else????????????? Please help this female in ky~!!
Old 07-22-2004, 09:27 PM
timberdoodle timberdoodle is offline
well if you are sure your getting fuel up to the throttle body, then its not the fuel pump. Is the engine rotating and just not starting? Or is it not cranking at all? If it is turning the engine over then possibly you have some issues with spark. That could be a complexed story, try putting a starting light tool in line with one of your spark plugs and have someone turn the engine over while you look to see that you are getting spark, if you are then it could be some timing issues, if not you may have some detailed electrical problems, if you need more assistance, please drop me a line: [email protected]
