Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-22-2004, 04:46 PM
DUlrich1227 DUlrich1227 is offline
Send a message via AIM to DUlrich1227
Question feul filter
where is it ? Is there one ? Is it in the GAs tank ?
I did a search in the forum but nothing came up.
David
Old 07-22-2004, 06:30 PM
bobby95 bobby95 is offline
You better hope there is. What year? What engine?
Old 07-22-2004, 09:21 PM
Dromega Dromega is offline
I have a 97....the fuel pump and filter are in the gas tank.
Old 07-22-2004, 09:27 PM
JDPascal JDPascal is offline
Re: feul filter
Check underneath on the frame just in front of the back axle for the filter.
JD
Old 07-25-2004, 01:41 AM
jeep mechanic jeep mechanic is offline
Re: feul filter
driver side frame rail by rear axel
Old 09-08-2004, 04:33 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
it is inside your gas tank, it is part of your fuel pump assembly.
Old 09-08-2004, 08:49 PM
DIY Mechanic DIY Mechanic is offline
There is an external fuel filter.
Don't bother changing it unless you suspect water in the tank.
There is an internal filter as well.
It is a plastic mesh on the fuel pump pickup.
I have taken fuel filters apart for years and have never found any debris of any kind.
I have concluded that changing the fuel filter is a marketing ploy and not sound maintenance practice.
Believe me I am a maintenance fanatic.
The fuel filter has been dropped from my regular maintenance routine unless the system is breached or some problem makes the filter filament suspect.
Old 09-08-2004, 11:11 PM
Re: feul filter
Sorry bout that I was referring to DROMEGA he said it was a 97 (which is located in the fuel tank, it is part of the fue pump assembly). on most earlier models (93-96) it is an inline fuel rail which is outside the tank, and located near the rear axle mounted to the frame. there it 2 little tabs on each line, just squeeze them and pull the lines off. easy way to check the fuel filter is to blow in it, if u feel alot of resistance then replace it but if it flows thru pretty good then it is fine.
