Old 07-22-2004, 04:22 PM
anthony90si anthony90si is offline
rad swap
would a rad from a teg fit into a 90 si. cause i found a aluminum one at the junk yard.
Old 07-22-2004, 06:35 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
90 to 93 teg yes... you'll need the teg cooling fans too though...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 07-22-2004, 10:33 PM
Hybrid1990crx's Avatar
Re: rad swap
I tried to put the fluidyne radiator into my civic from my integra and it was way too tall.
Old 07-23-2004, 04:05 AM
Re: rad swap
uh ok so a stock rad should fit.
Old 07-25-2004, 09:17 PM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
Re: rad swap
i had to modify my hood when i did my LS swap to fit the LS radiator in there, i had to cut notches out of the sides (just inside the headlight) also
cut a hole in your inner hood to fit the radiator cap up inside it when you close the hood.
-Josh
B18A into 90 hatch, daily driver
projects:
all kinds of fun and wierd honda projects/conversions,
funnest is SBC into 90 hatch, RWD conversion, turbo400 tranny.. it's a cut and weld thing
Old 07-26-2004, 03:35 AM
91civicDXdude's Avatar
Re: rad swap
funny... i've installed 3 90-93 integra radiators into EF civics of all sorts (2 hatches and 1 4 door) with no problems whatsoever. bolted rigth in like it was factory.
Old 07-26-2004, 11:18 PM
Re: rad swap
huh.. that is odd.. the bottom pins fit into the stock mounts but it's just tall i guess
if you tip it back toward the engine it'll work wihtout too much modifying but i wanted it as far forward as possible for turboing my LS so i had to notch and cut a bit.. so it's nearly straight up and down.
-Josh
projects:
