Old 07-22-2004, 01:36 PM
liftedhoe liftedhoe is offline
Question clearing check engine light
random misfire code came upand i replaced the crank angle sensor before clearing first code. now its saying its getting wrong readings from new sensor.but runs fine.i was told code should have been cleared first before putting in new sensor. if i unplug new sensor and clear code then disconnect battery before plugging in new sensor will that turn off light and if not then how ......... i ve been told to buy another sensorand do it like i first explaned
Old 07-24-2004, 07:21 AM
verdejt99 verdejt99 is offline
Code
How did you clear the code? From my understanding the only way to really clear codes in 96 and newer is with a scan tool.
Old 07-25-2004, 12:46 PM
well i used a scan tool first and it cleared code for probably 5 min then light came back up checked code again then tried undoing battery with the ame results as before . called dealer with them telling me to clear code then replace sensor. im trying to not have to spend 100 $ on a new sensor when nothings wrong with the one in it but just to get light out
Old 07-25-2004, 01:53 PM
tealse tealse is offline
96 is the first year for the vortec and also obdII .You need a scanner to reset the ses.
Old 07-25-2004, 02:36 PM
70camaro 70camaro is offline
Re: clearing check engine light
I cant imagine it makes any difference WHEN you reset the code. When you reset the ECM, the error has to occur again to set SES to on.
Old 07-25-2004, 07:17 PM
i was told the obdll had the specs from the first sensor in memory so the new ensor with the new specs was causing it to throw up the new code and turn on the light due to the specs NOT MATCHING IF THAT MAKES ANY SENSE
