Old 07-22-2004, 09:48 AM
zebra123 zebra123 is offline
Engine swap, reusing existing axles
Hey all,
Am going to be doing a Civic D series engine swap. Will be reusing the (nearly new) existing axle assemblies in the 'target car' and not the axles from the engine 'donor car'. That in mind, I've seen it illustrated in a manual (somewhere) that the axle assemblies were apparently left attached at the wheels and the engine was still able to be removed, and of course reinstalled. Is this true ? If 'yes' how is sufficient play obtained to extract the splined shaft from the transmission while its still attached at the other (wheel) end ? Assuming this is doable, is it worth what looks like extra hassle (working around these half shafts while still constrained at one end...) -is it worth it to NOT break the shafts loose at the wheels and simply get them out of the way entirely during the swap ?
Thanks
Greg
Old 07-22-2004, 01:42 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: Engine swap, reusing existing axles
ive seen that method done also, but only in magazines too. without unbolting the hub assembly from the control arms, i cant see of a way to get that much play either. its prolly a whole lot easier to just remove them and not to cuase any damage.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
