Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 07-22-2004, 01:17 AM
rgraham rgraham is offline
5 beeps 5 times
say i have 5 beeps 5 times after the engine is running. something to do with the air bags. any sugestion?
Old 08-08-2004, 02:02 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: 5 beeps 5 times
your air bag warining light is inop - this is a safety feature to let you know theres a problem when the system can't light the bulb properly
-=-=-DANE-=-=-
Old 08-15-2004, 02:41 AM
Re: Re: 5 beeps 5 times
yes, the air bag lamp does not light. I will try replacing the lamp and get back with a report.
Best Regard
Robin
08/15/04
I replaced the indicator lamp and the beeps have stopped "GOOD."
now the air bag lamp comes on 3 time and then 6 times and repeats.
At least i can live with that!
Thank you so very much!
Old 08-17-2004, 06:04 PM
Re: 5 beeps 5 times
flash code 36 is for the pass. side impact air bag circuit - there is an updated harness for this problem - if you have side impact bags the job is a pain in the rear - but if you don't actualy have side bags the replacement harness takes about 5min. to install
-=-=-DANE-=-=-
Old 08-26-2004, 08:19 PM
thanks for the expert help,
after replacing the front wheel bearing $175 i was able to check out the airbag wiring harness. i used your advice and search under the back of front seats and found two yellow connectors. i unpluged them and reseated them a couple of times and "wa law" the airbag lamp did not come on. man now i feel good about paying $6500 for this 1999 mountaineer. now if only i could get the fix sheets on the radio display it would be running at 100%.
just another useful site
http://www.ford-trucks.net/
again thanks
Old 11-14-2004, 10:07 PM
Doug Rodrigues Doug Rodrigues is offline
Send a message via MSN to Doug Rodrigues
The radio fix can be had at http://www.shareamemory.com/radio for the low price of $20. That will be the best $20 you ever spent.
