Old 07-22-2004, 12:05 AM
cheezwizard cheezwizard is offline
Acceleration Lull/Response question
Hey dudes, Cheez Wizard here. I've a '99 3.5L GX w/ 87k.
I've only had my car for 4 months or so, that's why I post every time I notice something. Forgive the Cheez Wizard for this, won't you?
This question is regarding the
responsiveness of the gas pedal/engine.
In first gear, it will take-off into second (over 3k rpm if hit hard).
Once at a cruising speed of say, 35-50 on local streets, the acceleration hits a lull.
The accelerator won't respond if pressed down gradually. I'll have to press significantly, kick the RPMs up over 3k and hear the engine revv to increase speed (by more than I want to).
It doesn't just increase gently, gradually, as I think it should.
Don't get CW wrong. I drove a 4 cylinder for 10 years before buying the Olds. Needless to say, I dig the power.
I jsut like to be able to slowly increase speed. My Olds isn't doing that. I have to crank the engine up to increase speed, and then , immediately step off the gas to drop down to the speed I intended.
Just checking if other owners have this gas pedal issue.
Thanks folks,
CW
Old 07-25-2004, 06:49 PM
Puffnstuff's Avatar
Puffnstuff Puffnstuff is offline
Send a message via ICQ to Puffnstuff
Re: Acceleration Lull/Response question
Check your air filter and make sure that it isn't clogged. My wifes intrigue was sensitive to a dirty filter and go as far as stalling under throttle until it was changed but hers was a 3.8.
06 Toyota Tundra Double Cab
