Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-21-2004, 11:08 PM
othello othello is offline
Vibration while accelerating
My anxieties are now escalating. My beloved 1988 Camry with 330k miles is exhibiting a strange shimmy while accelerating. The front vibrates noticably only whenever I'm above 60mph and actively gaining speed. There is no vibration in the steering wheel.
I have replaced worn tires, worn tie rod ends, and worn engine mounts. These have not cured the shaking. The tire shop also recommended new struts and strut mounting plates, but I don't believe they are causing the problem.
So what are the obvious answers? The one answer that occurred to me is too terrible to contemplate. My mechanic did not find any metal filings in the transmission base, fortunately, although there was less fluid than normal.
Old 07-21-2004, 11:22 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Vibration while accelerating
lower ball joints or wheel bearings?
Old 07-22-2004, 03:15 AM
Bossman Bossman is offline
You might want to give some more thought to new struts, etc. I had mine replaced on my 89 Camry wagon because they were worn out and flat-spotting the tires and thus causing a flapping/vibrating sensation at highway speeds.
Old 07-22-2004, 09:14 AM
GSS123 GSS123 is offline
Bad CV joints like Brain said.
Old 07-22-2004, 12:15 PM
nmikmik nmikmik is offline
If you search this forum for ‘vibration’, you will see lot’s of posts on that. Mine was cured after replacing bent axle (result of worn struts and motor mounts)
Old 07-22-2004, 08:57 PM
Many thanks for the suggestions. I will formulate a plan of further attack. The Meineke shop that's done my brakes (and one botched strut job) for the last 10 years will take a look at the situation. At least now I'm armed with more information up front and won't just blindly accept their diagnosis.
Old 07-23-2004, 10:34 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Don't forget to check the motor mounts...
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
