Old 07-21-2004, 10:43 PM
Knight2040's Avatar
Knight2040 Knight2040 is offline
Send a message via AIM to Knight2040
washer fluid tank leaking
alright when i bought my car last week it had no washerfluid so i went to autozone today and bought some and when i poured it in my washer fluid tank it just poured stright through the car and poured all over the ground like the bottom the tank was cut off....now is the tube where u fill it up at is directly connected to the tank, so it can't leak from there right? i'm having a hard time looking down toward the tank cuz this engine bay is so crowded. is it difficult to remove the tank so i can inspect it?
1991 Mitsubishi 3000GT VR4 Twin Turbo- Forged Ross Pistons,Forged Crank,Forged and Shotpeened Rods,Stillin DP,K&N FIPK,Greddy Type-RS BOV,Magnacor Wires,Aluminum Y-Pipe,EGR Blocked,All Gutted Cats,Greddy Turbo Timer,Blitz Boost Guage,Autometer A\F Guage,Solid Shift Bushings,Red Top Batt,ACT 6 Puck Clutch,Free Boost Mod,99 Front End Conversion
Old 07-21-2004, 11:26 PM
Hotshot8792 Hotshot8792 is offline
its not hard to remove the tank, very very easy
take the battery out of your car, just disconnect it from negative first, then from positive
after that, there are 6 bolts you have to undo, 4 12mm bolts that holds the battery tray to the brackets, and 2 10mm bolts that hold the washer resevoir to the battery tray, undo those, everything pulls right out (although the wiring harnesses are still attached, just follow the wires to you find where it is attached at which will be at the corner of the engine bay, disconnect and you can take the resevoir around with you, if you dont intend on seperating it from the car then you dont have to unplug it, you'll see what i mean after you do so)
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-21-2004, 11:33 PM
John Pannebaker John Pannebaker is offline
Re: washer fluid tank leaking
Don't you have to worry about the radio codes when you disconnect the battery
Old 07-21-2004, 11:52 PM
Igovert500's Avatar
blue + red light magnet
If you have the stock stereo and don't have the radio codes, then yes that would be a concern.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
