Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 07-21-2004, 09:43 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Oil fittings for KA24DE-T
I know this is a longshot, but does anyone on here know what fittings are required for running an oil line from the oil pressure unit to the turbocharger. I am aware that you can use a T fitting or a sandwitch, but I need exact sizes. This will be much cheaper and quicker than the import autoperformance kit. Thanks.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 07-22-2004, 01:15 AM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Re: Oil fittings for KA24DE-T
What you will need:
-3AN hose (varied lengths)
1/8" BSPT to 1/8" NPT adapter (1)
1/8" NPT to -3AN adapter (4)
1/8" NPT Female T
Remove the oil pressure sender. Put a 1/8" BSPT to 1/8" NPT adapter into the block. Then put a 1/8" NPT to -3AN adapter into the one you just put in the block. Get a 1/8" NPT Female T. Put a 1/8" NPT to -3AN adapter into the bottom part of the T and on one of the sides of the T. Run a short -3AN line from the 1/8" to -3AN adapter in the block to the same adapter in the bottom of the T. Screw the oil pressure sensor into the side of the T that has no adapters in it. Screw the last 1/8" to -3AN adapter into the turbo (NOTE: This size will vary depending on the turbo you use. Most garrett turbo's accept this size though, and I'm just guessing that you're using a garrett). Now on the other side of the T that already has the adapter in it, run a -3AN line from that to the adapter you just screwed into the turbo.
Old 07-22-2004, 07:24 PM
240SX Guy
Thanks for the help, but I just bought the Import-Autoperformance kit. I didn't want to tear it all apart and find out that I bought the wrong fitting. Couldn't find the -3an 3/16 ID line around here either.
-Cory
12.6@122mph
