Old 07-21-2004, 06:31 PM
MoshimoGTP's Avatar
MoshimoGTP MoshimoGTP is offline
Send a message via MSN to MoshimoGTP
Question Drilled Zzp-tstat Question
What do you recommend for hotter climate, here were i live the temps are about 100-120+F, if i install a zzp modified tstat can affect me?, the temp are too high for that cars, the normal temp in my car is about 210, and my car has 160 TSTAT custom drilled.
What do you recommend, i have installed the hi-speed fans and prestone coolant.
Thanks
RED 1999 Grand Am GT - RAM AIR V6 H.O., 4drs, sunroof, and more!
Old 07-21-2004, 06:34 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: Drilled Zzp-tstat Question
Mosh,
If you get the DHP it will help keep the car cooler. I believe the fan turn is 180 for DHP I believe.
Might look into an electric water pump offered by zzp or intense
Old 07-22-2004, 08:37 AM
carnutcass's Avatar
carnutcass carnutcass is offline
210* isn't going to hurt your car. Although, I'm a little surprised that it doesn't run cooler with a drilled 160* stat.
Old 07-22-2004, 04:22 PM
Ripn12s's Avatar
It gets pretty hot in the south. I see 195-210 everyday.
Old 07-22-2004, 07:06 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
I live in Florida. 180 is what I use in my 2 GTPs. Run a 160 in my GT. Don't know why that one runs warmer.
