Old 07-21-2004, 04:52 PM
blacktallon2000 blacktallon2000 is offline
What Can Cause A Weak Spark
I installed a rebuilt dizzy in my 1990 dx. But it's almost impossible to start the car. It takes a lot of playing with the dizzy for the car to even start and when it does it doesn't run well. The spark is extremely weak so we took the dizzy out and installed it in another car. It started right up. Strong spark there.
What could be the problem? my car is not starting without loosening the dizzy and moving it around. One mechanic told me to check the ECU. I did with the whole jumper thing, but the CEL does not blink at all. what could be the cause of the weak spark.
It seems as if it sparks sometimes and doesn't spark at other times.
Could it be the timing and if so how do I adjust the initial timing.
I've had this problem for over a month now and the problem is that there are no good mechanics in my area so that's why I want to try to fix it myself.
please help
Old 07-21-2004, 05:54 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: What Can Cause A Weak Spark
have you checked your plug wires?
Old 07-21-2004, 06:11 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
check your plugs too while your in there......
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 07-21-2004, 06:16 PM
the plugs are fine and the wires are fine. bought a new set just last week. It sparks but really weak.
Old 07-21-2004, 10:18 PM
Hybrid1990crx's Avatar
maybe a relay? Did you check all your grounds?
Old 07-21-2004, 10:45 PM
BullShifter's Avatar
Re: Re: What Can Cause A Weak Spark
Coil, igniter, battery, rotor, cap, wires
Main relay wouldn't be a problem with spark because it controls fuel.
Timing - http://www.binghamtonlife.com/manual...s/91-23-58.jpg
Full manual - http://www.binghamtonlife.com/manual/2gsm/default.htm
Old 07-21-2004, 10:49 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
When my ignition coil cracked, my plugs were still sparking but weak as hell. it was cracked inside an arking all over. but you said it got strong spark installed in another vehicle so could something else. cant hurt to check it.
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 07-22-2004, 08:43 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
make sure your connections are good and not loose
Team Lonely Drivers
