Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 07-21-2004, 04:18 PM
fredmeister75 fredmeister75 is offline
Keyless entry programming for 2001 Sunfire
I just bought 3 keyless entry remotes for a 2001 Sunfire. Does anyone have the programming instructions?
Thanks
Old 07-21-2004, 06:52 PM
Robbie1's Avatar
Robbie1 Robbie1 is offline
Re: Keyless entry programming for 2001 Sunfire
I don't know if this will help you but,
on my 98 Sunfire with the keyless, you press and hold the lock and unlock buttons when you are close to the car. The doors lock and unlock and your done.
Not sure if this will work on yours, but maybe it will help.
Old 07-28-2004, 05:22 PM
groovie groovie is offline
Thanks
I HAVE THE PROGRAM FOR A 2000 SUNFIRE NOT SURE IF IT WILL WORK ON YOURS IN THE CAR CLOSE DOOR (HOLD THE UNLOCK) BUTTOM PUT THE KEY IN AND TURN (NOT ALL WAY JUST TILL RADIO & STUFF IS ON )THE ONE BEFOR ACTUALLY TURNING THE CAR ON DO THIS THREE TIMES WITH THE KEY LEAVE KEY IN THE IGNITION IN OFF POSITION LET THE UNLOCK BUTTON GO YOU SHOULD HEAR THE LOCKS CYCLE UP & DOWN THEN TAKE THE KEYLESS REMOTE AND HOLD DOWN BOTH BUTTONS UNLOCK & LOCK YOU SHOULD HEAR THEM CYCLE TO PROGRAMM TAKE KEY OUT EXIT AND TRY.....YOU SHOULD DO ALL THIS NOT TO SLOW BUT GO RIGHT ALONG.......HOPE THIS WORKS FOR YOU IF NOT THEN ARE YOU SURE THAT YOUR CAR IS EGUIPED FOR KEYLESS?
