Old 07-21-2004, 03:08 PM
KMoney28 KMoney28 is offline
Send a message via AIM to KMoney28
Suggestions on an amp
Hey, if you guys have any suggestions on an amp, let me know. I am looking for a good quality amp at a fair price to put out anywhere from 1800-2400 watts RMS.
Old 07-21-2004, 10:54 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Suggestions on an amp
Do you realize how much 1800-2400 watts is?
Do you have about 500 dollars? that is how much you are looking at spending for a cheap one.
www.cloudcity.deviantart.com
Old 07-21-2004, 10:57 PM
I'm aware of the power, it's either 1 big one or 3 small ones to power each sub, I prefer 1 big one.
Old 07-21-2004, 11:14 PM
Haibane's Avatar
2 big ones? for 500 will give you 2400... cheapest power I can find that sounds good... What are you using this to power? people hit around 160+ with that kind of power to 2 subs, about 1000 each
Old 07-22-2004, 12:10 AM
I'm trying to power 3 S12L7's close to full potential. They're 750RMS peak each, i wanna get them around 600 RMS each. If I get 2 amps won't I have to wire it where the ohm load will be raised thus causing the amp to be less efficient? I thought it would be better to get 1 huge amp or 3 smaller amps, 1 to each sub, that way you can lower the ohm load of the amp, am I wrong?
Old 07-22-2004, 12:20 AM
Haibane's Avatar
You know what kind of ohm load you would get on one amp... something really weird like 1.33... but you would probably want 3 amps
Old 07-22-2004, 12:28 AM
Any recommendations on types of amps?
Old 07-22-2004, 12:33 AM
Haibane's Avatar
avionixx, tsunami, edesigns, hifonics
Old 07-22-2004, 12:38 AM
Cool, I look around at those. I wanna make it hard on the inside, right now it seems to be loud, but most of the sound seems to be trapped in the trunk. I dynamated and removed a plastic piece that was behind my back armrest. This helped a little bit, but not like what I was expecting. Could my sound troubles be because my subs are in a custom sealed box? Should I consider going ported? Or is it the lack of power from my one amp(MTX 8001)?
Old 07-22-2004, 12:45 AM
*I'll look around *I wanna make it hit hard on the inside, not just be loud bass
Old 07-22-2004, 01:19 AM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
you should go ported.. it'll make your setup louder seriously.. and yea... 3 amps are better than 1 HUJANGUS amp.. well tahts just what i think hah
Old 07-22-2004, 09:26 AM
Haibane's Avatar
Well actually if you had the money I would go with one Tru power amp and keep it sealed. With 3 subs, you need to keep all the quality you can get...
Old 07-22-2004, 09:43 AM
Haibane's Avatar
http://www.dgce.nl/nl/dept_57.html
the H1
http://www.advanceae.com.au/car/prod622.htm
Old 07-22-2004, 03:10 PM
A friend of mine recommended these amps: Earthquake PHD5000W, AutoTek MX 3000.1, Planet Audio VX2200D, Power Acoustik A3000DB, SPL Z1X3000D, Cadence ZRS-10
Anybody heard of these? Are they any good?
Old 07-22-2004, 03:19 PM
Haibane's Avatar
cadence is good... that is it
