Old 07-21-2004, 01:06 PM
Brndo Brndo is offline
Question 92 Lumina Vacuum lines location????
My 92 3.1 6cyl Lumina cant change vent position and cruise control is out. Figured it was vacuum line problem after reading similar threads...HOWEVER...I cant find the lines...How many are there...are there any diagrams available...where are they...any common locations of failure? Would love to have A/C in vents and cruise control back...Any help would be great. Thanx.
Old 07-21-2004, 01:56 PM
goldwinger goldwinger is offline
Re: 92 Lumina Vacuum lines location????
Can't say where they all are but a good place to start is the vacuum ball under the front left fender, you have to remove the inner fender liner, and look in front of the tire. You can trace the lines from there. good luck
It's better on a bike!!
Old 07-21-2004, 03:12 PM
Ok, found vacuum ball, right after the "L" shaped boot that connects to the ball the line was cracked-almost broken off-I had enough slack to cut off the damaged part of the line and reinsert it into the boot, then reconnected it to the ball-but it didn't fix the problem. Guess the line is broken somewhere else too. Also, can I isolate the vacuum lines that might be the problem knowing that as far as I can tell only the vents and the cruise control are affected? Thanks for the info.
Old 07-21-2004, 04:02 PM
Kooterskkar Kooterskkar is offline
Send a message via AIM to Kooterskkar
Another place to look is by the evap canister under the coolant resevior. My cruise didnt work in my corsica right after I got it. I found a break in the line right by there. Fixed that and my cruise started working. Dunno about the hvac controls though, they've always worked fine.
Old 07-21-2004, 04:16 PM
newfslumina newfslumina is offline
another good place to check is by the battery. you will have to remove the battery to find them. once you get the battery out you can also trace them back to the back of the engine. that is where my problem came from.. hope this helps
Old 07-28-2004, 03:45 PM
Ok, thanks that will get me started, gotta get some time tho...I'll let ya know if and where I find anything...
Old 07-30-2004, 03:44 PM
the~~kidd the~~kidd is offline
i assume u havent found them yet if u havent look on top of ur intake manifold, there should be two little hose and a little bit bigger one there thats where they start and from there one goes to map sensor and the other to cruise control and the bigger one to a sensor
Old 07-30-2004, 04:35 PM
eag21 eag21 is offline
Same problem. Vacuum lines ok.
Was a bad vacuum canister. $95.00.
Old 07-30-2004, 04:42 PM
ouch, thanx for the price
Old 08-02-2004, 09:18 AM
battlechaser1212 battlechaser1212 is offline
Send a message via AIM to battlechaser1212 Send a message via MSN to battlechaser1212 Send a message via Yahoo to battlechaser1212
when i accelerate the A/C goes through the vent but all the vacuum hoses are fine but i did find one by the battery lying around it has plents of suction so im ritty sure its not suposed to be free falling but if it is please let me know. My lumina is a 98 standard ive heard things about a ball that a vacuum hose may go into but not sure where it is exept for the fact thats its on the drivers side by the bumper. please help
Old 08-02-2004, 03:45 PM
jandj jandj is offline
Another good place to check is inside the pass. side fender where the a/c lines go over the coolant tank. There's a 5-way plastic fitting, one larger line coming in and four going out. The "prongs" will break off the fitting. Sometimes there's enough left to reattach the line , otherwise head for auto parts and replace the fitting.
Old 08-03-2004, 05:53 PM
Well, I fixed my vacuum line problem on my ’92 3.1 L. I now have A/C out the vents and my cruise control works! Besides the break in the vacuum line I fixed and wrote about above I found another. If you follow the vacuum line out of the vacuum ball to the first intersection of lines there is what is more or less a “T’ intersection. The “T” is hard plastic and looks similar to a short cylinder with a cone on top. (One piece though.) It was cracked and looked like there was even a small piece missing. The dealer had a whole vacuum harness assembly for $25, but I just wrapped the “T” with electrical tape to seal it and the problem was fixed. Hope this helps someone.
Old 08-07-2004, 04:58 PM
I cant find my vaccum ball on my 98 chevy lumina and want to know where it is and what it looks like i found the vaccume but not the ball.
