Old 07-21-2004, 11:30 AM
Bonzai Fighter Bonzai Fighter is offline
[Need Help] Problem after ZC Swap
Hey Friends,
I have the following Problems with my 4th Gen Civic DX
I Swaped a D16Z5 CRX (EDM) 1.6l DOHC MPFI Engine into my 90' Civic ED6 (90HP D15B2 DPFI)
I use the PM7 ZC ECU an a complete ZC engine. I followed the DPFI to MPFI Guide to install the missing wires.
But the engine has the following probs:
The red Oil Preassure Warning Light is on all the time.
The orange Engine Warning turns on when I start the Engine.
The Engine has 4000 U/min when turned on. (and not the normal 1500 when I start a cold engine)
ECU says: Code 9: Cyl. Sensor ?!
But I'm sure I installed the wires for the Cyl. Sensor (blue/geen & blue/yellow) correct?! (Pins C1 & C2 @ ECU)
Anyone knows Help?
[Sorry for my bad english, i'm from germany]
Old 07-21-2004, 09:15 PM
POSRacing POSRacing is offline
Send a message via AIM to POSRacing Send a message via Yahoo to POSRacing
Re: [Need Help] Problem after ZC Swap
well my pm6 ecu has said code nine since i did my install but then my zc isnt running right now, if i may ask you? do you have a ecu pinout chart showing positions c1 & c2?
Old 07-22-2004, 02:02 PM
Sorry,
as I said my english is not very good. So could you please explain to me what a "ecu pinout chart" is?
Perhaps this could help you?! -> http://www.fourthgenhatch.com/mpfi.html
Arne
