Old 07-21-2004, 10:25 AM
screamingchild screamingchild is offline
Send a message via AIM to screamingchild
Question Cigarette Fuse issue
alright.. I just joined specifically becuse of this problem..
I have a 99 grand am se
and the fuse in the Cigarette lighter is blown...
I have the hayes manual as well as the owners manual that comes with the car.. and I cant find which fuse to replace.. then only thing that comes to mind is that that GM calls a Cigarette lighter something else..
thanks for you help
NOTE: I got it fixed.. incase anyone runs into the same problem it is a 2 amp fuse (#34) in the fuse relay box under the hood
Old 07-21-2004, 10:28 AM
Pvt_Murphy Pvt_Murphy is offline
Check the fuse boxes on either side of the front; u know the ones u can get to when u open the doors; if the sticker on te cover doesnt say it just look for a blown fuse
1977 Pontiac Trans Am Olds 403
Rolling like the Bandit!
Old 07-21-2004, 10:34 AM
Re: Cigarette Fuse issue
I did check all of the fuses.. I pulled all of them out and they all semed to be fine. I know I did not short out the battery or something because the car still starts and everything else works.
Old 07-21-2004, 10:36 AM
catback23 catback23 is offline
the cig lighter is also a courtesy item so look for your courtesy fuse that also runs other convenient things like the radios memory.
Maybe your cig lighter is bad, did you check for power to it?
Old 07-21-2004, 10:39 AM
Re: Re: Cigarette Fuse issue
I plug my radar detector in there. and there was no response.. so I used the Cigarette ligter and it did not get hot. I will check into the courtsey fuse thing though.thanks!
Old 12-29-2004, 08:57 AM
h2opologoale h2opologoale is offline
Send a message via Yahoo to h2opologoale
Re: Re: Re: Cigarette Fuse issue
i have the same problem on my 94 grand am.... i pluged some neon lights into it and they dont work i checked the cig. lighter and that doesn't heat up... also my power locks dont work are they connected on the same fuse? where is the courtsey fuse box? please help thanks
Old 12-29-2004, 09:15 AM
Re: Re: Re: Re: Cigarette Fuse issue
i just checked my car and i came to realize that there is no courtsey fuse box but rather a courtsey fuse labled ctsy and sure enough that was it... that you for all your help i probably wouldve checked them all thanks alot and hopefully i'll have no more problems
