Old 07-21-2004, 07:43 AM
LT1MAN LT1MAN is offline
Banned
Unhappy Lt1 Driveshaft
I have a guy that can build custom driveshafts from chromoly steel. i was wondering if anyone has converted from a 2 piece driveshaft in an lt1 to a 1 piece. im trying to figure out if it makes the car ride bad or not. i know it will free up some horsepower considering it will be 20 lbs lighter than the stock driveshaft.
thanks fellazzzzzzzzzzzzzzzzzzzzzzzzzzzz
Old 07-21-2004, 08:42 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Lt1 Driveshaft
first, when the heck did the LT1 have a two piece driveshaft? thought only the sixers came with that.
second, im currently looking into this idea. assuming that the supposed LT1 two-piece has the same geometry as the sixers: you cannot just take a one piece out of an LT1 and put it in place of the two piece, the lengths are different. however, the only part of the shaft that has a different length is the slide yoke(heard it called that) that slides into the back of the transmission. my theory is: get a one piece shaft, and then just switch out the slide yoke with the one off of the two piece shaft...
Old 07-21-2004, 09:33 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Re: Lt1 Driveshaft
i just took apart a wrecked '97 z28, it didn't have a 2-piece. i think u have engine's mixed up or something...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 07-21-2004, 09:47 AM
Deadcarny Deadcarny is offline
Re: Lt1 Driveshaft
the V 6 cars had a 2 piece driveshaft. even with the different lengths, several V6 owners have swapped in 1 piece shafts with no problems and no modifications. I sole a 1LE driveshaft to a guy with a V6 a couple months ago.
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100
1967 Chevrolet Impala (Sold)
1972 Chevrolet Chevelle (Sold)
1972 BMW R60/5 (Sold)
1980 Harley Davidson FLH
1987 Harley Davidson XLH
1992 Astro EXT AWD
1992 Chevrolet Cavalier
2000 Monte Carlo SS Pace Car 1087/3222 (Sold)
2001 Pontiac Sunfire
2002 Trailblazer LTZ (Sold)
South Carolina F and Y Bodies
www.SCFYB.com
Old 07-21-2004, 12:38 PM
Re: Lt1 Driveshaft
yeah im pretty sure that the LT1 never came with a two-piece. it would have torn that two-piece all to hell. maybe the guy has a car with an engine swap.
on a more "me" related topic: the v-8 shafts fit right into the sixer cars? i figured that they would cause theres no difference between the drivetrains, but im always skeptical of these things cause they never work out for me...
Old 07-21-2004, 04:03 PM
Dober89 Dober89 is offline
Re: Lt1 Driveshaft
As far as I know any driveshaft from 84-02 is interchangable as long as it doesnt have an odd transmission in it.
Old 07-22-2004, 08:31 AM
Re: Lt1 Driveshaft
word...
Old 07-22-2004, 09:46 AM
Re: Re: Lt1 Driveshaft
yea, i believe 3rd and 4th gen cars driveshaft's are completely interchangable, the one on the '97 i took apart was the same length as my '92
Old 07-27-2004, 06:41 AM
Banned
Re: Lt1 Driveshaft
thanks,
i believe the lt1 does have a one piece, the chromoly shaft sounds like a plan after i get my headers and ypipe in.
