Go Back   Automotive Forums Car Chat > Warehoused Archives > Introductions
Introductions Welcome to AutomotiveForums.com. Introduce yourself here so we can get to know you better.
  Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-21-2004, 06:46 AM
Brian D Brian D is offline
94 olds flooding under load
I just bought a 94 Olds Cutlass Supreme 4 door 3.1 v-6. It starts and runs good at city speeds. The intake gasket was changed before I bought it. It will sporatically miss and clouds of black smoke will billow from the tailpipe. This happens more frequently when in over-drive. I let off the gas momentarily to clear it then press the gas pedal again and it fixes itself for a minute then starts flooding again.
Could this be a coil pack or fuel pressure regulator?
There's so many things that it could be I don't know where to start.
Any advise would be appreciated. I'd like to fix one or two things not 20 if possible.
Brian D
Old 07-21-2004, 01:50 PM
meyersjm7 meyersjm7 is offline
Re: 94 olds flooding under load
Brian D
Brian I would start with the fuel pressure regulator.Do you have a check engine light on when this happens?
Old 07-21-2004, 02:14 PM
I have had the check engine light come on when flogging it after a high RPM run - Matted! but it went out shortly after.
Brian
