Go Back   Automotive Forums Car Chat > Automotive Articles > Technical Corner > Technical Articles
Old 07-21-2004, 01:55 AM
igor@af's Avatar
igor@af igor@af is offline
Your friendly AF Admin
Send a message via ICQ to igor@af Send a message via AIM to igor@af
Superchargers: Compressor Design and Choices
SUMMARY: There have been several different supercharger designs used in automotive history, but only a few remain in common use today. This discussion will explain how each works and give some basic information on the advantages/disadvantages of each.<br>
View full article
What do you think about this story? Post your comments below.
Old 03-14-2008, 12:57 PM
panic panic is offline
Re: Superchargers: Compressor Design and Choices
The analysis of the screw types has a serious and fundamental error. Quoting: "As the two rotors spin, the lobes interlock to form nearly airtight sections within the supercharger housing."
This does not happen - the rotors never interlock.
On all G.M.C., Roots, Eaton etc. the lobes interlock as they pass each other, but this is only for clearance - no work or pumping occurs between the 2 mating lobes. The working area is the volume between 2 sequential lobes on the same rotor and the case inner wall, and it's only moved (but not compressed).
On all screw types, the working area is the inter-lobe volume between the male and female rotors. It's larger at the intake end, and decreases along the length of the rotors until the exhaust port. This change in volume is the compression. If the rotors interlocked the compression would be infinite (except for safety clearance and leakage).
Old 07-06-2009, 07:43 AM
leash75 leash75 is offline
hello i have a holden commodore v6 superchargered motor L 67 or m90 eaton supercharged i would like to know if there is after market rotor with 3 blades or can i have contact details for company and how much thanks
