Old 07-21-2004, 01:53 AM
Kaimenship Kaimenship is offline
I need some help on Sanding/Polishing/Waxing
Okay, so i got myself a modena 360 and i don't want to screw it up.
After priming and sanding, I mist painted 3 layers of tamiya italian red and weat coated 2 layers.
After 2 days, I did the same with some testors clear coat i had laying around.
Another 2 days pass and i start sanding. I've noticed i've got a bit of orange peel. I sand up to 2000 grit all while wet sanding it..
I just can;t get rid of the hint of orange peel....
I figured some compounder and wax might get it out...
I end up with this.
upon closer inspection i see this on the hood
and
note the peel is still there....
any suggestions?
Old 07-21-2004, 02:20 AM
tpliquid tpliquid is offline
Send a message via AIM to tpliquid
Re: I need some help on Sanding/Polishing/Waxing
sand some more? than polish it
friends let friends drive benzes
Old 07-21-2004, 02:27 AM
sjelic's Avatar
sjelic sjelic is offline
It will be hard to get it out, but it is possible, in the future wet sand the primer first to get smoth surfice and then send again beffore clear coat. Now the only thing to do is to sand it untill orange peel is of (so you need some serious sanding) affter that (if you haven't gone through the colour all the way to primer) just give few clear coats to get it shiny and if you go throug the paint you will need to repaint it completly. Try very slowly maybe you will get it out, the problem is once you apply clear coat it is hard to get to paint with rubbing compound only, so sanding is only option, work slowly and you might get it right. By the way it is not as bad as you think, just a bit more sanding, and clear coat of course.
Sasa Jelic
SCALEMAKERS
Old 07-21-2004, 03:25 AM
campenr.1's Avatar
campenr.1 campenr.1 is offline
With the two dents you already have I woukd suggest start over again.
Strip the paint and then Prime - sand - Colour - sand - clearcoat - sand -compound polish - wax polish.
Old 07-21-2004, 03:37 AM
ridefast's Avatar
ridefast ridefast is offline
More sanding is obvious here, but... Before you start take a close look at your model again. If you think that more sanding might cause rubbing through the clearcoat (or what's even worse through the base colour) consider clearcoating it again. It might be a better solution than removing the whole paintjob and starting again from the scratch. With a bit thicker (and maybe smoother) clearcoat you can sand your model as smooth as it should be without the risk of repeating the whole process.
Oh, and BTW I wouldn't sand down or even polish the base coat before clearcoating it unless it is a solid colour. Sanding metallic or pearlescent finishes can leave ugly marks. The bad news here is: you won't be able to get rid of them with polishing or in any other way because the marks will be 'trapped' under the clearcoat.
I am sure Sjelic speaks from his own experience and uses the kind of paint that allows that kind of procedure.
Good luck
Old 07-21-2004, 04:20 AM
sjelic's Avatar
Yes sorry I should have mentioned that I use automotive paints only, here is picture affter polish with automotive polish without clear coat.
Sasa Jelic
SCALEMAKERS
