Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 07-20-2004, 10:44 PM
v8less_tuner v8less_tuner is offline
engine swap
new to this forum. bit of a honda person and the toyota has been making it's way to being one of my favourites, especially the MR2. my question is about an engine transplant, and whether or not it is possible to swap a 3SGTE from a 90'-93 MR2 into a 86 or 87 MR2. does it require custom motor mounts or is it a straight swap. past that are there any other engines recomended that are either easier to swap in or are more powerful, any input or information on this swap would be helpful. thanks
Old 07-20-2004, 11:17 PM
ghetto7o2azn ghetto7o2azn is offline
im not that knowledgeable of the mk1 but i know that it isnt a direct swap... it think it does need custom motor mounts but it is possible... i know that someone in this forum did it or is currently doing it, and can probibly give you more information as for the difficulty and money that is required for it
Old 07-21-2004, 12:40 AM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
Re: engine swap
yes it is possible. click on the car in my sig to see mine. it is a VERY involved process. if you look through the pics + commentary and still have some questions, just post them up here, and i'll be glad to answer them for ya.
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 07-23-2004, 11:31 PM
redmk1na redmk1na is offline
Re: engine swap
its very possible many people have done it it's not that easy, not as easy as you think taking one engine from an mr2 and putting it in another. Its comonly reffered to as the mk1.5 as far as I know less than a dosen people have actually done this swap and posted it online. But its worth it the swap alone will have you running 0-60 in about 4.5 seconds, not bad for 200 horses. Another good swap to consider is finding a 20v 4age and putting that in which is really nice if you can afford someone to custom build a turbocharger or supercharger.
Old 07-23-2004, 11:54 PM
ac427cpe's Avatar
Re: engine swap
update on 0-60: passenger can't click the stopwatch, too busy holding on
i agree, a 20v is a good swap as well, but you still have wiring to deal with. though, wiring is much easier on its own.
hello, i am Dan
Old 07-24-2004, 12:12 AM
Re: engine swap
thats funny hows that mk1.5 taking care of you
Old 07-24-2004, 12:48 AM
Re: engine swap
interesting, suppose this is my first swap (which it is) would it be best to go with the 20 valve because of less wiring, and later upgrade to a turbo/super charger. plus... how well do the tranny and engine match, is there anything going on there i should be aware of like further fabrication or drilling.
Old 07-24-2004, 12:29 PM
Re: engine swap
I think the 20v is a little easier, and the tranny should match, but it's not the best one, I cant remember, but I think the best one is the tranny thats on the 20v
Old 07-24-2004, 01:19 PM
ac427cpe's Avatar
Re: engine swap
the 20v will be easier, not because of wiring (you'll still have a lot) but because you don't have to cut, weld and clearance anything. there was a red one on ebay a couple months ago... so it is possible to do.
hello, i am Dan
Old 07-25-2004, 12:49 AM
Re: engine swap
cool... about the mr2 mk1.5 project, ive been looking at that thread and i saw that you had two sets of motor mounts going, the ones that you cut and then just below it there were some red ones, what are those all about.
Old 07-25-2004, 06:18 AM
bigd1180 bigd1180 is offline
i have a 87 mr2 too
my mr2 is smoking bad and was looking to get a different motor and i found a 91 4age with the chome on silver cover does anyone know if it will fit
Old 07-25-2004, 07:56 AM
ac427cpe's Avatar
Re: engine swap
the ones we cut are the side mounted ones (welded to the car) they were painted w/ the engine bay, and the red ones were some that we modified to take a solid mountable bushing. they are front and rear.
hello, i am Dan
Old 07-25-2004, 08:27 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
Re: engine swap
yeah that'd be the 20V ... any 4a-g will fit... or should do!
Old 07-25-2004, 08:28 PM
TRD2000's Avatar
Re: engine swap
although i wonder who would select an engine for their car on the basis of cam cover pigmentation?
Old 07-25-2004, 08:32 PM
does this motor require wiring or can i use the intake and distributer out of old motor or does the new one need the four throttle bodys that are on ot I guess what i am trying to say (not very good at explaining myself) can i use the tvis system on the block of the new 91 4age thanks in advance guys
