Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 07-20-2004, 09:58 PM
chrismcmurtry chrismcmurtry is offline
h22a fuel injectors
looking to replace my existing stock fuel injectors...what kind should i get? i keep seeing rc engineering? what size??? peak & hold or saturated?
Old 07-20-2004, 11:15 PM
del del is offline
móddə rąytər
Re: h22a fuel injectors
what mods do you have? and how much power are you producing? that will determine if you have a need for higher cc injectors.
Old 07-20-2004, 11:24 PM
i have a h22a and my mods are:
apexi ws cat-back
hi-flow cat
obx header
cold air intake
msd 8.5mm wires
msd blaster 2
msd 6a ignition
skunk2 cam gears
unorthodox (3) pulleys
i don't know how much power i'm producing yet b/c i've only got 700 miles on new rebuild and it's not all perfect yet...but i know i want to get better injectors, a rail, regulator, fuel filter, and better fuel pump...i know aem is a well know name with the rail, regulator & filter...but it's double the price of obx...is aem that much better???thanks
Old 07-22-2004, 01:21 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Depends on your year. OBD1 should run peak and hold, and OBD2 should run saturated. To me, you don't have enough mods to justify larger injectors. All you'd do is let the mixture run rich. Think about a nitrous or turbo kit, and then upgrade injectors.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 07-22-2004, 10:11 AM
ok thanks.....what if i just want to replace my existing stock, old injectors, what should i do or get?? i just what to make sure everything is in absolutly perfect shape!
what about a rail, regulator, filter, and pump???
