Old 07-20-2004, 10:44 PM
RossT RossT is offline
should there be a slight vacuum when you open the gas cap
I recently purchased a 91 metro. I replaced the metal fuel fill tube that runs from the fuel door down under the left rear tire to the flexible line that eventually runs into the gas tank. MIne was rusted from the salt that flings up from the rear tire.
I pulled a perfect one from a 91 metro in a junk yard.
I know notice that when I remove the gas gap, there is a slight vacuum
build up that releases.
The cap says to open carefully. Is this vacuum a safety feature to keep gas fumes in the tank?
Or do I have a problem somewere with not enough venting of outside air when the car is running?
Thanks
Old 07-21-2004, 02:37 PM
Mike_Van Mike_Van is offline
My '96 metro does this virtually every time I fuel up an almost empty tank. I believe it's not a problem.
Old 07-21-2004, 07:49 PM
mcalvo's Avatar
mcalvo mcalvo is offline
Send a message via MSN to mcalvo Send a message via Yahoo to mcalvo
Re: should there be a slight vacuum when you open the gas cap
RossT:
The vacuum you talk about is perfectly normal. The effect is the same when you put even water into a bottle and shake it. Maybe you did not notice it before because the old tube that you replaced had tiny holes which let escape that pressured gas.
Hope this helps you clarify out your doubt.
Regards,
MC.
Old 07-22-2004, 02:00 AM
Thanks for the information!!
Old 07-22-2004, 11:43 AM
allthatwanders allthatwanders is offline
Yea, I have a 97' and it's always done the same.
Old 07-22-2004, 05:53 PM
geozukigti geozukigti is offline
It's actually the vacuum from the engine. Your gas tank has a vacuum line that goes from the top of the tank, to the charcoal filter under in the engine bay, then to the intake manifold. It prevents pressure from building up in the gas tank.
