Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-20-2004, 09:30 PM
IntegraT IntegraT is offline
only solutions please headlamp conden . .
i bought a set of aftermarket headlamps for my 99 gs-r and now i have condensation on the driver side headlamp i haaaaaaaate it. Nothing is worse . . . but sitting next to a hot chick that doesn't even know u are there, but u think she does!!!!!!!!!!!!!!!!
Old 07-21-2004, 02:01 AM
integralover's Avatar
integralover integralover is offline
you can take some of that clear silicon and go around the edges of it.
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 07-21-2004, 03:55 AM
wickedplastikman wickedplastikman is offline
Re: only solutions please headlamp conden . .
use an exacto knife to cut the seal to separate the headlamp in 2 pieces. then, take a blowdryer blowdry the inside of both pieces to remove any moisture that is in there. be careful not to touch the reflective metal because you will leave fingerprints that are a pain in the ass to get off. when you are done, put the pieces together and use clear silicone to re-seal the lamp. should take about an hour to do and then however long to let the silicone dry.
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
Old 07-22-2004, 01:25 AM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
easier/longer way: pull out light bulb and stick a blowdry in there a long ass time. or lieka heat lamp if u have one. or a portable heater.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 07-22-2004, 02:29 AM
that works too, but i like the other way because if you cut the seal and reseal it, you might fix the problem. otherwise you might just evaporate the moisture for now and then more moisture will appear later.
99 teg ls turbo:
Old 07-22-2004, 02:39 AM
Re: Re: only solutions please headlamp conden . .
For sure. Your way is def. better, but just suggesting an alternative.
Clear Corners
Iridium Spark Plugs
