Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 07-20-2004, 08:12 PM
chrismcmurtry chrismcmurtry is offline
water leaking in
my trunk and passenger side interior were filling up with water when it rained so i cleaned out the hoses on each side of the interior of my trunk and now the trunk doesn't leak but the pass side still does so can anyone tell me to find the hoses up front to clean out? thanks
Old 07-20-2004, 08:13 PM
Re: water leaking in
Old 07-20-2004, 09:10 PM
viet_lude's Avatar
viet_lude viet_lude is offline
Send a message via AIM to viet_lude
um... wats wid the two posts?
Dis_Boi
I like rice.(as in the food)
1. Ricer Any oriental import(not always) car that has been modified for no real performance gain.
(Ricer: car with no engine mods, a body kit, and possibly stickers. Made to look fast.)
Old 07-20-2004, 09:12 PM
sorry first time posting
Old 07-20-2004, 09:35 PM
bobinohio84's Avatar
bobinohio84 bobinohio84 is offline
Send a message via Yahoo to bobinohio84
Hoses?
Old 07-20-2004, 09:41 PM
the ones in the trunk are drain hoses i think there for the sunroof, i've heard from 3-4 different people that my inside leaking b/c there are the same kind of hoses somewhere up front???
Old 07-20-2004, 09:45 PM
Ur sunroof doesn't seal?
Old 07-20-2004, 09:47 PM
I got an 84 prelude and mine does'nt have what ur describing. Do u have a book?
Old 07-20-2004, 09:49 PM
I gota go but gl and I hope u find out what it is. Sorry I can't help.
Old 07-20-2004, 09:51 PM
mine is a 93...it's not my sunroof...i can pour water on my pass side wiper and it goes inside, so i took off the hood, wipers, and cowl started pouring water in different spots and the only place i could get it to come in the car was if i poured directly in the big hole with the filter thing i think it's the blower motor, BUT the water doesn't come in in the same spot so i don't think that is it????? HELP
Old 07-20-2004, 10:01 PM
dbebesi's Avatar
dbebesi dbebesi is offline
the hoses are for your sunroof. and there is four hoses. two in the front windshield posts. two in the rear glass post. they are supposed to funnel water down the trunk rails, or out the front rails. i have never heard of one clogging, but if it did, that would have nothing to do with water in your trunk. the only problem there could be the floor leaking, or the trunk seal itself is bad. the sunroof hoses run to the outside of the actuall trunk seal. but it could be your other problems. who knows? anyhow, you need to take out all the windshield post trim, the door post trim, and the back glass trim, and all the handle's and dome lights, and then the headliner. that would give you full access to the hoses. have fun. sucks to be you.
Old 07-21-2004, 12:13 AM
it comes in from up behind the glove box to the far left like you would be reaching in the fender from the inside but you can't and it's a lotttttttt of water not a drip i mean a river
Old 07-31-2004, 12:29 PM
h22 h22 is offline
This might help... bear with me my english ain't great. There is a plastic cover outside, bottom of your windshield; where windshield wiper motor is mounted. Take it off and check for seals to the fire wall or check air outlet from evoporative core of your heater or A/C that hides under the dash. The outlet should be on the passenger side under the same plastic cover. If this post makes no sense to you disregard it. That's how I fixed similar problem on a 97- prelude.
Serge.
Old 08-02-2004, 12:40 PM
omega_2099 omega_2099 is offline
I have a 93 prelude and I have the same exact problem. My passenger side floor is soaked when it rains and the trunk also gets water in it. I tore up all the carpeting on the passenger side and ut a silicone bead around the screws that mount the seat to the floor. That seemed to help but I just got a bad sotrm last weekend and my floor is soaked again.....ANYONE WITH INFO ON HOW TO FIX WOULD BE MY HERO. I cant find where the water is getting in.....HELP!!!
Old 08-02-2004, 02:30 PM
ludegal ludegal is offline
yea i have a 92 and it has the same exact problem....i at first thought it was cause a few screws were missing where the seats are bolted in....but i siliconed them and it still leaks...it sux cause it messes up my velour interior
