Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-20-2004, 07:27 PM
indmny453's Avatar
indmny453 indmny453 is offline
Send a message via AIM to indmny453 Send a message via Yahoo to indmny453
O2 sensor
i have a accord with a "high flow cat" now my rear O2 sensor is throwing a code. what can i do to get the light from coming on ??? thanks
Old 07-20-2004, 09:14 PM
pheurton-skeurto pheurton-skeurto is offline
Re: O2 sensor
since your accord is a 96 and im sure its getting up there milage -wise i would advise buying a new rear O2 sensor. honda says you should replace O2 sensors every 90,000 miles. when you put the free-er flowing cat on, the dirty o2 sensor wasnt able to read as well as it could with the stock cat, but thats just a guess...
1997 Honda Prelude Base
18G Turbo - 8 Psi
GReddy EVO Catback
1995 Honda Civic LX
Bone Friggin' Stock
Old 07-20-2004, 11:19 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: O2 sensor
yup replace the o2.
Old 07-20-2004, 11:30 PM
indmny453's Avatar
O2 sensor
the O2 sensor is fine i still have the stock cat but no guts so what should i do from there ? should i go ahead and get a O2 simulator or what else should i try to solve this prob. thanks in advance
Old 07-24-2004, 08:35 PM
Re: O2 sensor
seriously...just buy a new O2 sensor!
it will run you close to $90 for a universal one (which just requires a bit of extra wiring...nothing im sure that you couldnt tackle). sounds like a bit much but it should make your car run a bit better and improve gas milage...
18G Turbo - 8 Psi
GReddy EVO Catback
1995 Honda Civic LX
Bone Friggin' Stock
Old 07-25-2004, 10:39 AM
boosted k20's Avatar
boosted k20 boosted k20 is offline
yea dude, listen to these guys. u need an new O2 sensor. how can u say the O2 sensor is fine and then say that u are throwing an O2 sensor code. what is the code saying? low voltage? u need a new O2 sensor. i got a O2 sensor code on my integra with 82K miles and as soon as i replaced it and reseted the ECU, the code went away. no problems since then. i baught my universal O2 sensor for $60 i think. u will have to wire it up yourself which isnt hard to do at all.
and if u dont plan on doing alot of heavy engine work on your car like turbo/nitrous, u dont need the 02 simulator. just replace the O2 sensor
www.MEDIUMRACING.com
Old 07-25-2004, 12:49 PM
mellowboy's Avatar
Re: O2 sensor
Bosch o2 cost about 60.
Old 07-25-2004, 01:54 PM
indmny453's Avatar
ok i will give it a shot allthough i really don't think that that is the problem. i've been told that the sensor is throwing the code because the cat is hollowed out and it's not doing it's job so the rear o2 is making my check engine light come on. thanks for your help
Old 07-25-2004, 09:15 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: O2 sensor
it is the problem, since you gutted your cat(highly illegal BTW) the 02 sensor is getting much different readings than what it was used too, buy urself a new o2 sensor and end the problem.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-26-2004, 05:38 PM
indmny453's Avatar
ok cool thank you all for your help.
