Turbochargers
Looking to put twin turbos on my ride....any thoughts out there....haven't ever seen it myself....someone out there has done it I'm sure....who makes the best stuff...how to go about it, etc.
I was going to install a procharger....looking at different options now. Thanks
'03 Stang V-6: Bored/Stroked(4.2L), Forged Crank, Wiseco Pistons, I-beam Rods, Crower Cam, Port/Pol Heads & Intakes, Radius valve job, Titanium valve springs, Ram air, NX wet (100 shot), Fluidyne radiator, JBA headers, Mac H-pipe, Borla side exit, Aluminum Shaft, Steeda race T-56, Truloc, 3:73 gears, Triax shifter. Tubular K-member, Steeda C/C plates, Steeda strut tower brace, Ken Brown shock tower brace, Steeda G-trac bar, Subframe connectors, Steeda 5-link, Eibach Prokit, Tokico Illuminas. |
Re: Turbochargers
Check out these sites for ideas and lots of info...www.toohighpsi.com,www.turbomustangs.com
Judging by you sig, i think you will be capable of putting a system together even if no one has done it before. Corky bells book(i can't think of name right now) is also a very good read.
1993 Grand-Am GT...SOLD! 1982 VW Rabbit.......SOLD! 1988 Cavalier..........SOLD! 1989 Mustang GT 5spSOLD! 2002 Celica GT-S 6spSOLD! 2005 Jeep GC, 5.7 HEMI, heated leather and Alpine goodys
Re: Re: Turbochargers
Thank you sir....on my way
Re: Turbochargers
Corky's book is Maximum Boost. Pretty much mandatory reading if you're building a serious turbocharger system.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears. |
Re: Turbochargers
Hell yes! Call me a freak, but I read that book for fun. I mean, I've learned so much from that book, I wouldn't doubt that the engine I'm currently building would have at least 100hp and be much more reliable than whatever I would have built if I had not read that book. Compare the cost of building an engine and turbocharger system vs the cost of that book, and its worth at least twice that much. Its not thin like those HP Books. I would not recommend Turbochargers by Hugh Macinnes(a HP Book), if you spend the extra 10 bucks for Maximum boost you get three times as much useful information. I mean, you could put together a pretty good turbocharger system from the internet and other books, but if you want to build a system as good as it gets for a shadetree mechanic, I highly recommend the book. I'm building every part of my turbo system(headers, exhaust, intake, etc) and everything is based off of that book. Its got chapters for carbureated, fuel injected, intake manifolds, exhaust headers, the rest of the exhaust, not to mention turbo and engine theory, new developments, an example build, etc. Its a very thorough book.
Re: Turbochargers
turbomustangs.com
Re: Turbochargers
turbo systems for mustangs are a new thing that not many people know about but it is rising fast. they make ans ass of power. and two small turbos would give you alot of low end power. turbos are better than procharger cause of the boost that can be obtained in the low rpm range. centrifugals only build boost with rpm rendering you useless on bottem end. a twin turbo kit is gonna run you about anywhere from 8000-10000 dollars. i would go for a single turbo kit for about 6000. there are many companies out there. watch out for turbodrivenconcepts, they have ripped of many people. they have changed their name i think. look up "turbo kits for mustangs" under search, there is one of the results that will give you a review on all the companies, good and bad with a list of phone numbers
Re: Turbochargers
$8,000-$10,000 TT and $6,000 for a single? Are you out of your mind?
Re: Turbochargers
dude i almost got one for mine and yes they are that expensive for a complete system. maybe you should do your homework bro.
BTW, why is it that my boosted 302 stroker keeps getting smoked by imaginary 96 cobras, whats up with that. |
Re: Re: Re: Turbochargers
Kris 2012 Genesis Coupe 2.0t |
