Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-20-2004, 03:43 PM
kkaralou kkaralou is offline
Question Radio Display
Here's a stumper. This display for my radio is completely gone. It doesn't show the time or radio station, etc. What's weird is that in the winter when I start the truck and it's still cold, it's on. After driving for a few minutes and the vehicle warms up, it goes off. Now that it's warmer it's been off all summer. I've checked the fuses, wiring, etc. It's a 98 Ford Ranger. Anyone have a similar problem before?
Old 07-21-2004, 09:01 AM
rb65dj rb65dj is offline
Re: Radio Display
Don't know the cause but I have owned several fords from 1988-1993 and each and every one of them had that same problem. Sorry I can't help you,maybe someone will be able to tell us all.
Old 07-27-2004, 07:41 AM
xaviermtb xaviermtb is offline
same problem
I have a 1997 Ranger, i love the truck, but the same problems occurs in my truck. The radio display will be on, sometimes off, either way the radio usually always works, just not the display. This has been the case for almost every ford vehicle my family has had. A windstar, expedition, and now the ranger....... whats the deal?
Old 08-06-2004, 01:28 PM
SWEENEY SWEENEY is offline
Re: Radio Display
I AM EXPERIENCING AN IDENTICAL PROBLEM ON A 98 RANGER. DID YOU FIND A SOLUTION? THANKS!!
Old 08-06-2004, 09:14 PM
DeerHunter301 DeerHunter301 is offline
Re: Re: Radio Display
Had that problem in a 98 Explorer...Dealer said it was a faulty resistor behind fuse panel....Not very electrically knowledgable, but I guess it makes sense. Dealer says tuner control and display control are on two seperate lines, each individually powered, and when one goes, the other will usually still work. Hope that helps.
Old 08-09-2004, 10:30 PM
Re: Radio Display
Dealer is giving you a first class "CON " job. Further investigation on my part has led me to find out this is an on -going problem with Ford over several years and vehicle. Cost to repair is excessive if you go to Ford and they refuse to admit liability. Take a look at this web site for possible help at a much lower cost. www.shareamemory.com/radio
