Old 01-30-2002, 08:32 PM
Mirt3 Mirt3 is offline
Send a message via AIM to Mirt3
cai install prob
im in the process of installing my injen cai....the last step says "replace the coolant line with the 6mm hose provided with the kit" but i have no idea what this coolant line is....is it a big deal if i dont replace it with the new one? quick responses are appreciated
-mike
Old 01-30-2002, 08:38 PM
CivSiGuy's Avatar
CivSiGuy CivSiGuy is offline
Banned
Send a message via AIM to CivSiGuy
:huh:
they might be stupid and be talking about the breather line.
I dunno.. if everything is secure and hooked up. Don't worry about it.
Old 01-30-2002, 08:47 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
Well, that hose is the only one you replace when you install an intake, so that has to be it.
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 01-30-2002, 08:57 PM
no it came with 2 hoses....it says "slip the 10mm hose from the vacuum fitting on the valve cover to the fitting on the intake" then it says "replace the coolant line with the 6mm hose provided with the kit" i got the 10mm hose on but i dunno what to do with the 6mm one..ohwell, i guess itll be ok
Old 01-30-2002, 09:03 PM
CivSiGuy's Avatar
Banned
if everything looks good.. i wouldnt worry
Old 01-31-2002, 07:39 AM
Kohhal's Avatar
Kohhal Kohhal is offline
Ok, here's what I think. Note: this is based on a 6Gen Dx, I'm assuming it's a similiar install.
The reason the coolant line has to be replaced on the 6Gen is because when you change the breather hose the stock coolant hose is permanently attached to it, so you need a new coolant hose too. I assume it's the same for you, so if your stock hoses were attached you'll need the coolant hose, otherwise, I guess you don't really need it?
HTH, G
A curse upon you Oliver Cromwell
You who raped our Motherland
I hope you're rotting down in hell
For the horrors that you sent
To our misfortunate forefathers
Whom you robbed of their birthright
"To hell or Connaught" may you burn in hell tonight
