Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-20-2004, 02:18 PM
wickedplastikman wickedplastikman is offline
how do you retard your timing?
we just installed a zex kit on my friends type r. right now we only have a 55 shot on it with the timing at zero. to put a bigger shot the directions say the timing has to be retarded 2degrees for each nozzle size we go up. so how do we go about doing that? other than the spray the car is stock.
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
Old 07-20-2004, 05:05 PM
Ziggymidget5 Ziggymidget5 is offline
Send a message via AIM to Ziggymidget5
Re: how do you retard your timing?
I have no experience with nitrous, so if it means cam timing, you need to get some adjustable cam gears. If it means ignition timing, you need to rotate the distributor 2 degrees towards the front of the car.
White 1995 Prelude Si 5-speed 107,000 miles
AEM CAI
AEM Pulleys
DC Sports CC Header
Carsound Hi-flow Cat
5Zigen Fireball Cat-back
17" wheels with 215/40/17 tires
Custom paint on some interior (yellow)
Currently in Progress:
KMS (Honda-performance.com) Camshafts, Valve springs, and Retainers
Skunk2 adjustable cam gears
Wish me luck on this project, something always seems to go wrong.
My 1995 Prelude Si
Old 07-20-2004, 05:35 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Old 07-20-2004, 07:55 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
if you are running stock ecu, i wouldnt even do a 55 shot
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 07-21-2004, 03:57 AM
thanks!!
99 teg ls turbo:
Old 07-21-2004, 10:34 AM
boosted k20's Avatar
boosted k20 boosted k20 is offline
-1st u need to place a jumper wire between the service plug connector (located above the passenger side kickpanel. it's usually in a green rubber casing. remove it from the casing and place a jumper wire between the plug (when u start the car the CEL will come on. this is normal)
-hook up an inductive timing light to spark plug wire # 1
-loosen but dont remove the three bolts holding the distributor assembly in place.
-start the car. Let it idle for a while until the radiator fan comes on. now aim the timing light towards the timing belt cover (down by the crank pulley) u need to aim it by the point/marker on the timing belt cover.
-if ur car is at 0 degrees advanced timing (timing set at 16 degrees), then the point on the timng belt should be lined up with the red marking on the crank pulley. U will also notice two white lines on both sides of this red marking. the white line closest to the front of the vehicle is timing set at 18 degrees timing (or 2 degrees advanced timing) and the one closest to the firewall is set at 14 dgrees timng (or 2 degrees retarded) u want to get the point on the timing belt cover to be lined up with the white line closest to the firewall(2 degrees retarded)
-with the distributor loosen, u want to move it towards the front of the vehicle. just give it a small tap and it should move. u want to move it in small increments. everytime u move the distributor, check the timing to see where the white line that is closest to the firewall is in reference to the timing belt marking.
-once u have this white line on the crank pulley lined up with the timng belt point/marking, tighten back up the distributor bolts. (u might want to check the timing once more to make sure u didnt move the distributor while u were tighten it up)
-remove the timing light and the jumper cable from the service connector plug inside your car. (the CEL will go off now)
make sure to remove this wire. i drove my car for a while with the wire still connected to the plug. nothing bad will happen to ur car. i think all it does is keep the timing of the car set at a certain value. i think the ECU wont be able to make adjustments to ignition timing when the jumper wire is still connected.
BTW ur spray n the Type R that is stock. u should at least get some I/H/E first before... wait a second, i forgot i was talking about a type R here. they already got good flowing exhaust. an intake will help though.
good luck
www.MEDIUMRACING.com
Old 07-22-2004, 02:33 AM
thanks boosted!! that is a damn good explanation. oh, and i apologize. the car does have i/h/e.
99 teg ls turbo:
