Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 07-20-2004, 01:21 PM
Jepster Jepster is offline
Question '96 LT1 Service Engine Soon light
My "Service Engine Soon" light was on, so I ran the codes and replaced the secondary air intake valve as indicated. The new valve is working perfectly, and I can't find any other reason that it should be on. Is there a way to reset the light, or is there something else I should check for first?
Old 07-31-2004, 05:47 PM
rickwhoo rickwhoo is offline
did you try disconnecting the battery
Old 08-03-2004, 01:15 PM
Re: '96 LT1 Service Engine Soon light
Yep. I actually just replaced the battery and the posts due to corrosion. I also checked the fuse.
Old 08-03-2004, 02:09 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
well the thing about the SES light is that there are always different sensors on the same circuit. so if a sensor that is on the oxygen sensor goes bad, then the computer will throw an O2 code, when in actuallity its some other sensor. what you have to do is somehow figure out what other sensors might be on that circuit and see which ones are causing the code throw...
Old 11-18-2004, 01:33 PM
04Vetter 04Vetter is offline
I had a 96 LT1 TransAm with the same problem. I thought I was going to shell out some bucks for the O2 sensors but a friend told me to buy some spray carb cleaner and clean the MAF sensor and it worked! Light went out and I only spent $3.
Old 03-02-2005, 03:56 PM
burd57 burd57 is offline
You have probably solved the problem by now but the answer is in the fuel cap OR fuel quality. Be certain the fuel cap is turned for at least 6 clicks and the service engine soon light should go out withing about 50 miles. If it doesn't, there is a deeper problem. THis has worked for me every time. Good luck!
