Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 07-20-2004, 11:35 AM
KWandKD KWandKD is offline
Key stuck!
I drove my 96' Sunfire SE to my work and back with no problems, but when I got home I couldn't take my key out of the ignition. It's stuck on the first switch. Its automatic and I tried putting it back in drive and then park again but no fix. Any quick solutions because my car is sitting outside with the keys in it, and it starts up fine. HELP!
Old 07-20-2004, 11:44 AM
Robbie1's Avatar
Robbie1 Robbie1 is offline
Re: Key stuck!
Try starting the car, putting it in neutral then back to park.
Try taking the key out of the car when you have it in neutral.
Some times you just have to charm the key a little.
Old 07-20-2004, 02:40 PM
jmoneydtb's Avatar
jmoneydtb jmoneydtb is offline
Send a message via AIM to jmoneydtb
also check the trigger on your shifter. in pontiacs if its not disengaged you cant take the key out of the ignition, and pontiacs do sometimes have a problem with the trigger getting stuck. sometimes i really wish they had put more money into quality than quanity.
94 Black Supra TT (half mine! )
....the beast lives once more....
Old 07-28-2004, 05:29 PM
groovie groovie is offline
Re: Key stuck!
THE NEUTRAL SHOULD WORK IF THE KEY IS EVEN A LITTLE BENT IT WILL GET STUCK OFF AND ON ALL THE TIME REPLACE KEY USE TO HAPPEN ON AN OLDER SUNFIRE I HAD ALL TIME BECAUSE THE KEY WAS BAD BUT YOU COULDN'T TELL BY LOOKING AT THE KEY SO IT ONLY HAS TO BE A LITTLE OFF
Old 10-09-2004, 02:54 AM
KTJNMD KTJNMD is offline
Key stuck
Sometimes in automatics, the shifter cable gets a little "off" and the car still thinks that it's in gear. Try jiggling the shifter back and forth in the park position and see if that works. If it does, you need to get the cable adjusted as soon as possible because it can get even more out of adjustment and you won't get the key out at all. Some locksmiths who do auto work in your area might be able to do this for you for sometimes less than the dealer.
