Old 07-20-2004, 11:21 AM
Chevysmallblock Chevysmallblock is offline
6 speed in a 92 rs
I was wondering what kind of trouble would it be to put a 6 speed in my 92 rs camaro (305) and about how much would i be looking at. It has a automatic at the moment.
Old 07-20-2004, 05:57 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: 6 speed in a 92 rs
contact www.fbodymotorsports.com, they will be able to help you out, and im pretty sure have all the parts youll need to do the conversion.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-20-2004, 08:59 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
you have to take out your swing pedals, and mount some from a manual tranny out of a 4th gen car (maybe third gen would work...), which would require u to take alot of things out of the engine bay so you can mount the pedals. you will also have to take out your center console and cut a hole for the shifter, since you have an auto. and you will have to get a new crossmember to mount the rear of the t56.
here's a link to spohn performance crossmembers, pick one depending on the tranny you want to put in. this is the company i bought mine from. i got mine with a driveshaft loop and the adjustible torque arm.
http://www.spohn.net/category.cfm?categoryid=1056
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
