Old 07-20-2004, 03:36 AM
coolguycooz coolguycooz is offline
Water IC?
Could somebody tell me how a water intercooler works? or a link to a site that explains it in full detail?
Old 07-20-2004, 07:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Water IC?
Same way a air to air intercooler works, except that instead of using air rushing through the IC to cool the charge (boost) air inside, it uses cold water.
The advantage is you can fill it with ice water and cool the intake charge to below ambient air temp, and you can use them when a regular front mount isnt a decent option because of packaging reasons. You also get shorter intercooler piping.
The drawback is that most liquids weight at least 8 pounds per gallon, so it tends to be heavy. And unless it has a heat exchanger at the front of the car (a small water to air intercooler that dumps the heat from the water back to the air, like on the Civic Si Vortech SC kits), it will eventually become heatsoaked and efficiency goes in the terlit.
Thats the better part of what air to liquid ICs are all about...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-20-2004, 12:31 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
Re: Water IC?
My idea has always been, repipe your AC pipes to cool the water. That should drop the temps wayyyyyyyyyy down.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 07-21-2004, 12:20 PM
AF - Advisor
Re: Water IC?
Flaco Racing I believe did that with one 798 rwhp Rx7 many years ago... Some poeple argue that having to drive the AC compressor will rob HP, but I firmly believe the substantial amounts of power you would gain from it would easily result in a net gain. And at 800 whp, I would think it works or they wouldnt bother with it
Kevin Jewer
Old 07-21-2004, 01:21 PM
Re: Water IC?
I could tost some rice with that rice burner.
