i don't know anything about them except how important they are, lol. but i read somewhere that an N/A engine with the right seals could rev safely up to 11grand! that seems quite nice to think about, lol. so what kind of seals, EXACTLY, would i need? also, to rev that high, what other engine components would have to be built or replaced or what have you...?
-jason thanks in advance fellas..
two40whippin OR rimfirejr3...is ME! lol |
Re: apex seals
You would need an ignition system to keep up. the stock ignition system cant handle it. And for that matter, why would you want too?? Your stock power curve has long since dropped off. 11k is reserved for b and p ported motors.
1988 10th AE Edition TII More mods then you have. |
Re: apex seals
if your revving much over 7k on a stock non-turbo then your wasting your time because the power drops off
1989 RX-7 TII --- Just got rebuilt and street ported RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II, 720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads HKS Blow-Off Valve, Stainless brake and clutch lines Last edited by Soyo; 07-22-2004 at 11:16 PM. |
Re: apex seals
unless you're a PP motor, 20B NA, or a wicked 787B car, then don't bother thinking about revving that high.
-1987 Mazda FC3S TII - dynoed 316rwhp 06.28.04 S5/S6 SP motor w/ HKA T04R @ 14psi CP Racing 4point Roll Bar Cusco ZeroII Coilovers SSR Watanbes RS-8 17x8F:17x9R - 1993 Mazda FD3S Competition Yellow Mica R1 - 1991 Mitsubishi Galant VR4 - daily grind JDM EVO RS motor w/ EVOIII 16G turbo |
Re: apex seals
an extended bridgey could have some power left at 11k rpm
but dont expect the engine's life to be long, (ppl are talking about race weekends because its unthinkable to use those engines in streetcars) so lets say 2 weekends for an extended bridgeported engine revin' at 11k.. (i say it will blow before 5 000 miles or it will start leaking and badly in need of a rebuild) the seal you wanna use are Carbon Seals, and they last about 20 000 miles, and they dont seal good under 8k, and they dont work good under boost or in nitrous engines. |
Re: apex seals
well... there goes that idea...thanks guys. lol. i don't care to rev that high at the cost of shortened engine life!!!!
LONG LIVE THE ROTARY, lmao...just fucking with ya
Re: Re: apex seals
it has been proven that rotary engines, under extreme circumstance, are so much more reliable than piston engines, for example, in dragracing, a V8 will need a rebuilt per run when a rotary can do 8 runs |
Re: Re: Re: apex seals
Re: Re: Re: Re: apex seals
F1 engines arnt modded engines, they are fully built by engineers and stuff. |
Re: apex seals
Well, some Honda JGTC engines are, and they rev pretty high. But i get your point
RX-7 TII |
Re: Re: Re: Re: Re: apex seals
In F1 cars, they shorten the connecting rods to reduce the piston travel, and thus the acceleration seen by the pistons. This prevents the connecting rods from breaking. Compression ratio decreases (worse than the pre-RX-8 rotaries), but the power delivery from a properly designed high-rev engine is unsurpassable, even with poor efficiency. Starting torque is poor, but real racers don’t give a ****.
They totally should use rotaries in racing. As always, the motorcycle scene is a step ahead. |
Re: apex seals
Re: apex seals
Why, are thay that much better?
The people of the valley lived happily and in peace for hundres of years. Then the atomic bomb was invented and they were all vaporized. |
Second, the piston engines that need rebuilding after every run are the ones putting out well over 2000 hp in the top racing classes. Funny car and Top Fuel both make 4000-5000 hp. Yes, they need rebuilds after nearly every run, but can the rotary even MAKE 4000 hp? Didn't think so. Rotaries were banned from a lot of racing classes simply due to the inability to agree on an actual displacement. F1 is based around displacement, and when the actual displacement was set at 1.5 liters, the 13B rotary was classed at 2.6 due to essentially being a 2 stroke design. When moved to 3.5 liters and no turbos, it simply isn't competetive (the 13B is rated at 2.6 liters, and cant make enough power without turbos, and the 20B is rated at 4 liters which is too large even without turbocharging. And again, without turbos, it simply doesn't make enough power).
I've owned over a hundred cars in the last 40 years. What was I thinking? ![]() 2013 MINI JCW Roadster 2023 Chevy Bolt |
