Old 07-20-2004, 01:56 AM
joemathews's Avatar
joemathews joemathews is offline
Exhaust Actuator
One of my buddies was telling me I should get some kind of exhaust actuator--a downpipe that has a panel that switches from releasing the exhaust right after the downpipe when it is open, to releasing it fully down to the muffler when it is closed. Apparently it is controlled by a cockpit switch. Anyone know anything about this, and how it performs as opposed to a full, full time exhaust?
The idea of being able to switch from quiet stock muffler to just a downpipe is very appealing ...and a nice sleeper-mod!
1996 Eagle Talon
Old 07-20-2004, 02:11 AM
coolguycooz coolguycooz is offline
I think there is something like that with a 3000 GT vr4 its stock you can flip a switch that does something simliar to that . That comes stock atleast with a 94 vr4 not sure about other years.
Old 07-20-2004, 03:24 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Exhaust Actuator
These have been out forever, do a search for electric cutouts... There are several makers, and several threads on tooners. I was looking at getting one for some time. The Quicktime Exhaust Cutout comes to mind, or something like that. There are others.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-20-2004, 07:04 PM
joemathews's Avatar
For archives' sake, I'll post some links for exhaust actuator electric cutout exhausts (word search name ):
http://www.mccordcg.com/mpp/mpp.htm
http://www.dmhperformance.com/ecutout.htm
http://www.racenet.net/missing.php?u...quicktubes.php
I do have another question however. A 2.5 inch downpipe is obviously all one needs unless they are getting into major power. Stock downpipe is supposed to be 2.25 in. Do you think it is necessary to buy an aftermarket 2.5 in. + downpipe and have the electric cutout welded to that, or could I get by with my stock downpipe and the cutout after that?
I'm wondering if the most restrictive aspect of the stock exhaust is the 1/4 in. less width in the downpipe, or the narrow bends in the catback and the cat itself, and how much power I would lose if I slapped a cutout right after my stock downpipe as opposed to buying a 2.5 in. and putting a cutout on that.
1996 Eagle Talon
Old 07-20-2004, 09:40 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
If I were you, I'd either get exhaust, OR a cutout. The reason a cutout is a good idea is because you can close it, and have stock exhaust when you aren't racing. If you get a free flowing exhaust like a 2.5 inch, which has been run down into 11's.. you aren't going to need a cutout (basically an open downpipe)
Old 07-21-2004, 12:19 PM
AF - Advisor
The stock DP is reportedly smaller than 2 inches at the front bend, all the heat shielding just makes it LOOK like its over 2 inches The number I heard was 1 and 7/8ths. Might have been RREs site, cant remember its been so long.
At any rate, I think a 2.5" DP is a required mod at some point, even if you stay with 2.5" catback and do a cutout, or whatever. The stock DP is a piece IMO.
Kevin Jewer
Old 07-21-2004, 02:06 PM
joemathews's Avatar
Okay that's what I needed to hear, thanks Kevin. So I need an aftermarket downpipe minimally.
1996 Eagle Talon
Old 07-22-2004, 01:08 PM
AF - Advisor
Well, need is a tough word. But I would say its worth the money. Remember that how much work a turbo can do is dependent on the pressure differential across the turbine wheel. Having the exhaust gasses able to expand into a nice large pipe helps. And the fact that you get faster spool and more creep is a testament to this. I think the best situation would be a 2.5" DP with a cutout for racing, but stock catback for minimum noise and maximum sleeper. Of course the neck down at the DP to catback joint wont help power with the cutout closed, but with it open it will no longer cost you any HP.
I too am considering toning down the exhaust... But the project has been put on the back burner, since I havent been able to drive the car on the street since april, lmao.
Kevin Jewer
