Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 07-20-2004, 02:50 AM
cyberknight cyberknight is offline
How do you remove the battery?
I know the battery is under the back seat and I was able to locate and unbolt it. How do you pry the battery loose? It is in a container with a hump up front that you can't slide the battery over. Is there some trick to getting this battery out that I'm not aware of?
Any advice or tips would be appreciated.
Old 07-22-2004, 12:07 AM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
Re: How do you remove the battery?
what kind of car are you talking about
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
Old 07-22-2004, 01:55 AM
Buick Riviera 95
Old 07-23-2004, 11:09 PM
MrBiggs MrBiggs is offline
Alll you have to do is take off the little rubber harness and that one bolt and just tilt and wiggle the thing loose. I took mine out nearly a year ago and replaced it with an Optima Yellow top. The stock battery is gargantuan and weighs a pretty good amount. Just keep trying, no tricks.
Old 07-24-2004, 01:23 PM
Thanks. I'll give it a shot.
